[GRASS-dev] d.graph compilation
Yann Chemin yann.chemin at gmail.com
Tue Aug 26 14:22:25 EDT 2008
It is ok now,
Thanks Glynn,
Yann
2008/8/27 Glynn Clements <glynn at gclements.plus.com>:
> Yann Chemin wrote:
>> d.graph is bugging on compilation:
>> root at siduxbox:/home/yann/tmp/grass/display/d.graph# make
>> test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p OBJ.x86_64-unknown-linux-gnu
>> gcc -I/home/yann/tmp/grass/dist.x86_64-unknown-linux-gnu/include  -g
>> -O2    -DPACKAGE=\""grassmods"\"
>> -I/home/yann/tmp/grass/dist.x86_64-unknown-linux-gnu/include -o
>> OBJ.x86_64-unknown-linux-gnu/do_graph.o -c do_graph.c
>> do_graph.c:25: error: static declaration of 't' follows non-static declaration
>> options.h:4: error: previous declaration of 't' was here
> Fixed in SVN, with:
> --- display/d.graph/options.h   (revision 33095)
> +++ display/d.graph/options.h   (working copy)
> @@ -1,6 +1,5 @@
>  extern float hsize;
>  extern float vsize;
> -extern double t, b, l, r;
>  extern int mapunits;
>  extern FILE *infile;
> It compiled without warnings for me; probably a difference between gcc
> 3.4.x and 4.x.
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
