[GRASS-dev] lib fn to convert int color number to RGB values?
Ivan Shmakov ivan at theory.asu.ru
Fri Feb 1 06:44:05 EST 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
 >>> RGBA_Color was recently added (as was RGB support for modules' CLI
 >>> options)
 >> Could the attached (untested) patch be of any help?
 > First, you would need:
 > -typedef struct
 > +typedef struct RGBA_Color
 >     unsigned char r, g, b, a;  /* red, green, blue, and alpha */
 > } RGBA_Color ;
	Indeed, thanks.
 > Normally, we use structure tags rather than typedefs. The RGBA_Color
 > structure and the STD_OPT enum are the only exceptions I see in
 > gis.h.
 > But, replacing color_rgb with RGBA_Color should be straightforward.
	That's what I believe I did with that patch.
