[GRASS-dev] Re: [GRASS GIS] #1: g.setproj bug: latitude_of_center and longitude_of_center ignored
GRASS GIS trac at osgeo.org
Sat Feb 2 13:40:04 EST 2008
  Reporter:  neteler  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.3.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:  proj
Comment (by martinl):
 Replying to [comment:3 pkelly]:
 > Re: the commented-out 7-parameter transform
 > I originally put this in and the source is now at
 http://www.asprs.org/resources/grids/08-2001-swiss.pdf
 > As far as I can remember the two reasons I left it commented were:
 > 1) The parameters given are for CH1903+ which is apparently different
 from CH1903 - I have no idea how much or if the differences are big enough
 to be relevant.
 > 2) I didn't have any test points to verify the parameters - in
 particular we always need to check the sign of the 3 rotation parameters
 (the 4th, 5th and 6th numbers out of the 7) as the American/European
 conventions are different.
 > If somebody can verify these two points then we can uncomment the
 parameters.
 I cannot varify it (maybe someone in grass-dev/user ML), but I would vote
 for uncomment the parameters and close the ticket (or to postpone it for
 6.4).
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1#comment:5>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
