[GRASS-dev] Re: [GRASS GIS] #1: g.setproj bug: latitude_of_center and longitude_of_center ignored
GRASS GIS trac at osgeo.org
Sat Feb 2 16:39:56 EST 2008
  Reporter:  neteler  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.3.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:  proj
Comment (by pkelly):
 Replying to [comment:5 martinl]:
 > Replying to [comment:3 pkelly]:
 > > Re: the commented-out 7-parameter transform
 > > I originally put this in and the source is now at
 http://www.asprs.org/resources/grids/08-2001-swiss.pdf
 > > As far as I can remember the two reasons I left it commented were:
 > > 1) The parameters given are for CH1903+ which is apparently different
 from CH1903 - I have no idea how much or if the differences are big enough
 to be relevant.
 > > 2) I didn't have any test points to verify the parameters - in
 particular we always need to check the sign of the 3 rotation parameters
 (the 4th, 5th and 6th numbers out of the 7) as the American/European
 conventions are different.
 > > If somebody can verify these two points then we can uncomment the
 parameters.
 > I cannot varify it (maybe someone in grass-dev/user ML), but I would
 vote for uncomment the parameters and close the ticket (or to postpone it
 for 6.4).
 Well, the original bug seems to be fixed according to Markus' comments, so
 no objections from me to closing the bug. I do object very strongly though
 to uncommenting the Swiss datum parameters without fully verifying them.
 People have been known to rely on and trust what GRASS does (ha ha ;)),
 and the onus is on us as developers not to let them down and verify stuff
 like this before putting it in there. I did a lot of research and double
 checking before I added all the datum parameters that I did, and while I
 can't remember the exact details of this one (was quite a while ago) it is
 obvious that I had some doubts or it wouldn't be commented out. So until
 someone does the work to verify that they are genuinely valid and work
 then IMO they should stay disabled.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1#comment:6>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
