[GRASS-dev] d.where -w problem
Duffy, Garret gduffy at nrcan.gc.ca
Mon Feb 4 10:45:08 EST 2008
I'm having issues with projections in GRASS.  I have two co-located
projects, one in UTM projection, the other in an Oblique Mercator
(omerc).  The problem I'm having is when I query the rotated Hotine
projection with "d.where -w", the returned Lat, Lon is nonsensical.
However, geotiffs exported from this GRASS project display correctly in
Global Mapper with other geotiffs from different projections.  So
something appears wrong with "d.where -w".
If Global Mapper is clever enough to deal with the coordinate
conversion, then I think GRASS should be able to deal with this.
Garret
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080204/9df24dd3/attachment-0001.html
