[GRASS-dev] d.where -w problem
Duffy, Garret gduffy at nrcan.gc.ca
Mon Feb 4 12:08:42 EST 2008
GRASS 6.2.2 (Margaretsville_rotated):~ > g.proj -pd
-PROJ_INFO-------------------------------------------------
datum      : wgs84
towgs84    : 0.000,0.000,0.000
proj       : omerc
ellps      : wgs84
a          : 6378137.0000000000
es         : 0.0066943800
f          : 298.2572235630
lat_0      : 35.0000000000
lat_1      : -20.0000000000
lat_2      : 20.0000000000
lon_0      : 20.0000000000
lon_1      : -120.0000000000
lon_2      : -60.0000000000
k_0        : 1.0000000000
no_rot     : defined
no_uoff    : defined
rot_conv   : defined
-PROJ_UNITS------------------------------------------------
unit       : meter
units      : meters
meters     : 1.0
GRASS datum code: wgs84
WKT Name: WGS_1984
Datum transformation parameters (PROJ.4 format):
        towgs84=0.000,0.000,0.000
-----Original Message-----
Sent: 4 February, 2008 1:02 PM
To: Duffy, Garret; grass-dev at grass.itc.it
Subject: RE: [GRASS-dev] d.where -w problem
>I'm having issues with projections in GRASS.  I have two co-located
>projects, one in UTM projection, the other in an Oblique Mercator
>(omerc).  The problem I'm having is when I query the rotated Hotine
>projection with "d.where -w", the returned Lat, Lon is nonsensical.
>However, geotiffs exported from this GRASS project display correctly in
>Global Mapper with other geotiffs from different projections.  So
>something appears wrong with "d.where -w".
If I'm not mistaken, I think you need to have "to_WGS84" parameter
shifts defined for your location for the -w flag in d.where to work
properly. Can you post the output of g.proj -pd?
~ Eric.
