[GRASS-dev] erratic behavior of v.in.ascii with WinGRASS
Helena Mitasova hmitaso at unity.ncsu.edu
Mon Feb 4 23:22:43 EST 2008
I did few more experiments (with a different file, but still
generated by GRASS - this time using v.out.ascii)
and it indeed looks like the fs=| is responsible
for the truly erratic behavior - I think that without quotes it is
represented as
pipe(?) so depending on where you put it you get different response:
at the end of the command:
GRASS 6.3.cvs (nc_spm_sed):~/grassdata/indata/ncdata > v.in.ascii
ftest.txt out=test2 fs=|
and nothing happens
or in the middle, before output (it never gets to it)
ftest.txt fs=| out=test2
ERROR: Required parameter <output> not set:
     (Name for output vector map).
I am wondering whether there are other commands that would need to
have this fixed
(at least on man page).
fs=| is default so it is probably rarely used (at least on command
line), but apparently
in needs quotes
Helena
On Feb 4, 2008, at 10:46 PM, Michael Barton wrote:
> Yet additional information.
> The file is messy because not all records have the same number of
> fields. Here is an example of 2 records.
> 628658.81149001|226880.93032087|9|-9999|-9999
> 636555.15570527|224580.64987627|10|125.6878585815||4|Managed
> Herbaceous Cover
> In fact these *should* be
> 628658.81149001|226880.93032087|9|-9999|-9999|
> 636555.15570527|224580.64987627|10|125.6878585815|4|Managed
> Herbaceous Cover
> My Mac will import the file in its original form, but crashes the
> TclTk when I use v.in.ascii from the GUI dialog. Another student's
> Mac imported the file with no problem.
> If I clean it up so that it is formatted like the 2nd pair of
> records above, it imports on my Mac fine.
> That said...
> 1) v.in.ascii should not crash any system if it encounters a bad
> file. It should exit with an error message
> 2) v.in.ascii in WinGRASS also crashed with a clean file on another
> student's computer today. It was a small one of 5 points. So there
> is still a problem under Windows.
> I tried running it from the command line with the messy original
> file. It did NOT import the points and output an error message to
> the terminal...
> Scanning input for column types...
> Maximum input row length: 89
> Maximum number of columns: 1
> Minimum number of columns: 1
> ERROR: y column number > minimum last column number
>        (incorrect field separator?)
> So... why does v.in.ascii go ahead with importing the points when
> run through the TclTk GUI when it does not import the points when
> run from the command line? The TclTk GUI has pretty robust error
> trapping now. So why does v.in.ascii bring it down? Could it be the
> 'formatting' of the error message? Something else going on
> internally so that it's not getting a message back to itself to NOT
> continue with importing?
> Michael
> ____________________
> C. Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
> On Feb 4, 2008, at 8:23 PM, Helena Mitasova wrote:
>> On Feb 4, 2008, at 9:45 PM, Michael Barton wrote:
>>>>> I've run into a problem running v.in.ascii for WinGRASS
>>>>> importing an
>>>>> ASCII points file. Sometimes it works OK. Other times, it causes a
>>>>> Windows dbf.exe error but still gets the job done. In most
>>>>> cases, it
>>>>> causes a dbf.exe error and only imports the first point--with a
>>>>> coor
>>>>> error.
>>>>> Here are a couple of other pieces of information.
>>>> can you 1) run it with 'g.gisenv DEBUG=5' and 2) make the input
>>>> file
>>>> and exact command line used available.
>>>> how about if you skip DB creation with '-t'?
>>>> Hamish
>>> We've used several files to test. But the main one is from the N.
>>> Carolina demo data set, external files for import <http://
>>> skagit.meas.ncsu.edu/~helena/grasswork/grassbookdat07/ncexternal/
>>> schools_el_lu.txt>.
>> that file was actually output from GRASS - this is the command:
>> r.what -f elevation,landuse96_28m null=-9999 < schools.txt >
>> schools_el_lu.txt
>> the original file is here (I assume that one works):
>> http://skagit.meas.ncsu.edu/~helena/grasswork/grassbookdat07/
>> ncexternal/schools.txt
>> Apparently I haven't tried to import it. It was probably generated
>> on Mac.
>> I can try it out and report back,
>> Helena
>>> This is a messy dataset, which may be part of the cause. But
>>> OTOH, it should behave the same way on all platforms and not
>>> cause a Windows dbf.exe error.
>>> v.in.ascii input=/Users/cmbarton/schools_el_lu.txt
>>> output=schools_lu format=point fs=| skip=0 x=1 y=2 z=0 cat=3
>>> I just tried it and saw it flash a malloc and dbmi error before
>>> it crashed the GUI
>>> I'll try the debug on my Mac. I don't think that will work on
>>> Windows.
>>> Michael
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
