[GRASS-dev] convert 3D polygons or Tins to a DEM?
Maciej Sieczka tutey at o2.pl
Tue Feb 5 03:55:32 EST 2008
Markus Neteler pisze:
> Hi,
> can we convert 3D polygons or tins to a DEM? Possibly a job for
> v.to.rast...
I did it this way:
1. Obtain the tin as a 3d shapefile with triangle edges as lines. This
can be done from ArcInfo/ArcGIS.
2. Translate each 3d line into 3d points, one point per cell in
accordance with current resolution.
3. Rasterize these 3 points.
4. r.surf.nnabthy alg=l interpolates a raster using linear
triangulation, recreating the TIN as a raster.
An un-polished shell code implementing step 3 is attached. Maybe you'll
find it usefull till no better solution in GRASS.
I don't rememeber why, but I rasterised the breaklines and main triangle
edges separately (you can separate them based on their attributes), then
patched rasters. Can't remember some details no; it's been some time.
There are comments in the script.
Maciek
Type: application/x-shellscript
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080205/36479dda/tin2rast_v4.bin
