[GRASS-dev] v.clean tool=rmline thresh= ?
Martin Landa landa.martin at gmail.com
Tue Feb 5 05:54:12 EST 2008
2008/2/5, Hamish <hamish_b at yahoo.com>:
> any reason why 'v.clean tool=rmline' doesn't respect thresh= to remove small lines? (like rmarea) Or is it just a matter of writing the code?
>   http://trac.osgeo.org/grass/changeset/24404
rmline should remove only collapsed lines/boundaries (zero-length). To
clean map geometry.
> workaround:
>  v.db.addcol column='DOUBLE length'
>  v.to.db option=length column=length
>  v.extract where='length > $thresh'
or better
to remove all lines/boundaries shorter than $thresh
v.edit a1 tool=delete query=length type=line,boundary thresh=-$thresh
longer than $thresh
It would be possible to modify rmline tool in v.clean to be
thresh-sensitive. Since v.edit do the job in the better way I think we
can leave rmline as it is.
Regards, Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
