[GRASS-dev] Re: [GRASS GIS] #29: moving of vector object by mouse
GRASS GIS trac at osgeo.org
Tue Feb 5 08:49:52 EST 2008
  Reporter:  zanollim     |       Owner:  martinl
      Type:  enhancement  |      Status:  assigned
  Priority:  major        |   Milestone:  6.4.0
 Component:  Python       |     Version:  svn-trunk
Resolution:               |    Keywords:  wxgui, digitization
Comment (by martinl):
 Replying to [comment:8 zanollim]:
 > after the ./configure (terminated with no errors)
 > when I run make the new error is:
 > make: shared: Command not found
 > make: [grass6_wxvdigit.so] Error 127 (ignored)
 > in the Makefile, inside the 'vdigit' folder, I read only this line with
 the word 'shared':
 > LDFLAGS=-shared -fpic -L$(ARCH_LIBDIR) $(VECTLIB) $(GISLIB) $(GDALLIBS)
 $(VEDITLIB) -lgdi $(WXLDFLAGS)
 Since this issue is not related to the bug, you can write me personally. I
 assume you run ./configure without any switches (from the error I can see
 at least without --with-cxx). I remember I prepared the script for
 configuration on your machine. It is called configure.sh, you need to run
 this script or ./configure with all needed switches.
 Regards, Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/29#comment:9>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
