[GRASS-dev] Re: [GRASS GIS] #36: v.generalize Assertion failed.
GRASS GIS trac at osgeo.org
Tue Feb 5 09:39:58 EST 2008
  Reporter:  marisn   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:
Comment (by wolf):
 The assert happens inside Vlib (the vector library). Could you please test
 v.build on a similar map, to see if it happens there too. Also can you
 provide a sample map where this problem occurs.
 Thank you,
 --Wolf
Ticket URL: <http://trac.osgeo.org/grass/ticket/36#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
