[GRASS-dev] erratic behavior of v.in.ascii with WinGRASS
Michael Barton michael.barton at asu.edu
Tue Feb 5 10:08:18 EST 2008
On Feb 5, 2008, at 5:44 AM, Moritz Lennert wrote:
> On 05/02/08 06:00, Michael Barton wrote:
>> Hi Helena,
>> It looks like the '|' is partly to blame, but not entirely.
>> If I use the original file with missmatched numbers of fields
>> between records AND use the '|' separator, I have trouble on my Mac.
>> However, if I fix the file so that all records have the same
>> number of fields (keeping '|' as separator) OR I leave the file
>> with messed up fields but replace '|' with ',' it works fine.
>> So it seems more a problem of reading the '|' separator in the
>> text file in some circumstances than it does having it in the
>> command string.
> Just to make sure: I don't think Helena meant that the '|' as
> separator causes any problems. It's the fact that you use
> v.in.ascii input=/Users/cmbarton/schools_el_lu.txt
> output=schools_lu format=point fs=| skip=0 x=1 y=2 z=0 cat=3
> with fs=| where | is unquoted and thus interpreted as pipe command.
Yes,
I understood. But it also looks like it's more complicated. In some
circumstances fs=| works OK (i.e., without quotes) and in other
circumstances it doesn't--suggesting that there also may be a problem
when v.in.ascii reads the | character in the ascii file in some cases.
Given these tests and what Glynn said (subsequent post), it seems
safest to always quote or escape the | character in v.in.ascii. In
this regard, is there a problem with making the default separator for
the g.parser section of v.in.ascii "|" instead of the current | ?
Seems like this would avoid problems when v.in.ascii is run in the
GUI (i.e., instead of having to change the default entry in the
separator field in each case).
As an aside, the | character seems like an odd default separator for
data fields in GRASS. I suppose it's a holdover from the ancient
past. But the fact that this is also has meaning as a pipe seems to
make it a risky separator in general. What about switching this to
something else in GRASS 7?
Michael
