[GRASS-dev] erratic behavior of v.in.ascii with WinGRASS
Moritz Lennert mlennert at club.worldonline.be
Wed Feb 6 04:38:03 EST 2008
On 05/02/08 17:17, Michael Barton wrote:
> On Feb 5, 2008, at 8:48 AM, Moritz Lennert wrote:
>> I would rather guess that depending on how the command line was
>> formulated, i.e. where the fs=| is placed, the command runs correctly
>> with the default values (i.e. '|' as seperator) or doesn't.
> Not in the case of my Mac gui crash. Exact same command argument order
> (in gui):
> fs=|   + different number of fields in different records (i.e., data
> file format bad) = crash TclTk
> fs=|   + same number of fields in all records (i.e., data file format
> good) = OK
> fs="|" + different number of fields in different records (i.e., data
> file format bad) = OK
> fs=,   + different number of fields in different records (i.e., data
As Glynn said:
> The Tcl/Tk GUI doesn't use the shell to execute commands, so it
> shouldn't be an issue there.
So, since all the above are done via the gui my guess seems to be
totally off anyhow...
IIRC, you said that you cannot reproduce this behaviour on the command
line, i.e. even the first case works on the command line ?
Moritz
