[GRASS-dev] v.clean tool=rmline thresh= ?
Martin Landa landa.martin at gmail.com
Wed Feb 6 05:04:31 EST 2008
2008/2/6, Hamish <hamish_b at yahoo.com>:
> > to remove all lines/boundaries shorter than $thresh
> > v.edit a1 tool=delete query=length type=line,boundary thresh=-$thresh
> Excellent. Thanks.
> > longer than $thresh
> (did you mean "thresh=$thresh" or "thresh=+$thresh" ?)
sorry, typo, I meant thresh=$thresh (or thresh=+$thresh)
> > It would be possible to modify rmline tool in v.clean to be
> > thresh-sensitive. Since v.edit do the job in the better way I think
> > we can leave rmline as it is.
> ok, but it's a bit inconsistent.
to rename rmline, to rmzeroline ?
Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
