[GRASS-dev] Re: [GRASS-user] build grass on osx 10.5-leopard (can't find opengl lib)
Sat Feb 9 16:00:45 EST 2008
Massimo Di Stefano wrote:
> i'm tring to build grass-svn
> on osx-10.5 but
> i'm having some difficoult to build it
> beacouse the configure step don't find
> the opengl libtraries.
> As explained in the macosx readme
> i need to modify the files :
> grass_trunk/include/Make/Platform.make.in
> grass_trunk/configure
> what i done :
> in Platform.make.in changed the line 160 to :
> OPENGLLIB           = -dylib_file /usr/X11/lib/libGL.dylib:/usr/X11/
> lib/libGL.dylib -undefined dynamic_lookup
> but in the file :
> configure
> here i'm having problems to undstand what needs a modify, i tried to
> replace all the :
> 		 " -lGL "
> with :
> 		"  -dylib_file /usr/X11/lib/libGL.dylib:/usr/X11/lib/libGL.dylib "
> or
> 		" -/usr/X11/lib/libGL.dylib:/usr/X11/lib/libGL.dylib "
> ....or again :
> 		" -/usr/X11/lib/libGL.dylib "
> but  the  ./configure ... ...   fail
> 		configure: error: *** Unable to locate OpenGL library.
> obviously (apologize me for these) i'm wrong to modify the configure
> file.
If configure can't detect OpenGL itself, use --without-opengl then
modify include/config.h and include/Make/Platform.make once configure
has finished.
