[GRASS-dev] Re: [GRASS GIS] #36: v.generalize Assertion failed.
GRASS GIS trac at osgeo.org
Sun Feb 10 04:10:07 EST 2008
  Reporter:  marisn   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:
Comment (by hamish):
 Daniel Bundala wrote on grass-dev:
 > Hello,
 > Finally, I had some time to look at it carefully. It seems to me that
 > the problem is the same as the one I mentioned earlier. I made a patch
 > some time ago, but for some obscure reasons, it did not propagate to
 > the SVN. I think that the patch should fix it as it is the only
 > difference between the version in SVN and on my computer.
 > Daniel
 > PS: I am not a big expert on CVS/SVN so the patch may be little out of
 > date.....
 The patch applied fine, now in SVN/trunk (r30050) and 6.3 release branch
 (r30051). It still needs testing.
 Should it use GRASS_EPSILON from include/gis.h instead of hardcoded 1e-12
 just do:
 $ svn up vector/v.generalize
 # make changes
 $ vi vector/v.generalize/smoothing.c
 # check it
 $ svn diff vector/v.generalize
 $ svn diff vector/v.generalize > v.gen_fix.diff
 "svn up" after changes should try and merge in any new updates which don't
 directly conflict.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/36#comment:5>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
