[GRASS-dev] Re: [GRASS-user] V.extrude... confused
Jachym Cepicky jachym.cepicky at gmail.com
Wed Feb 13 01:24:36 EST 2008
strange, I just tried out under Linux, works fine :-/ The vector map you
want to produce seems to be created anyway.
Maybe adding
G_percent(nelements, nelements, 1);
at the end of the module would help?
Jachym
Sampson, David píše v Út 12. 02. 2008 v 15:57 -0500:
> Hey folks.
> I want to make a 3d map of canada where each province is extruded base
> don certain values.  My provinces shape looked like it was being
> hassled so I thought ok, keep it simple.
> 1. created a small shape in the digitizer
> 2. v.extrude the vector with a single element
> 3. used 30 as my height
> v.extrude input=Ontario at sampson output=Ontario3D zshift=0 height=30
> type=point,line,boundary,area layer=1
> And it just hangs (output bellow).
> The green bar does not complete.
> I am using wingrass 6.3 cvs
> And as I'm in windows the v.extrude process is still running. When I
> kill the single process the whole GRASS session dies
> This is the output:
> 0 areas built
> 0 isles built
> Attaching islands:
> Attaching centroids:
> Topology was built.
> Number of nodes     :   19790
> Number of primitives:   20075
> Number of points    :   0
> Number of lines     :   0
> Number of boundaries:   0
> Building topology ...
> Registering lines:    1000   2000   3000
> 4000   5000   6000   7000   8000
> 9000  10000  11000  12000  13000
> 14000  15000  16000  17000  18000
> 19000  20000
> 20075 primitives registered
> Building areas:
> Number of centroids :   0
> Number of faces     :   20017
> Number of kernels   :   58
> Number of areas     :   0
> Number of isles     :   0
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
	=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
	=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080213/c031a941/attachment.bin
