[GRASS-dev] FFmpeg include files location
Wed Feb 13 15:50:12 EST 2008
Paul Kelly wrote:
> I've only ever compiled and installed FFmpeg myself, but it always puts
> its headers into ${PREFIX}/ffmpeg. Hence, when a C file includes these
> headers it should do e.g. #include <ffmpeg/avformat.h>.
Nope.
If you look at the top of the aforementioned avcodec.h, you will see:
	#include "avcodec.h"
In order for this directive to work, you have to compile with e.g.
-I/usr/include/ffmpeg.
> However
> lib/ogsf/gsd_img_mpeg.c includes files directly without the ffmpeg/
> prefix.
That's correct.
> Is this valid on any common Linux distributions
It's the correct way to include FFMPEG headers on all platforms.
> - are the FFmpeg
> header files directly in /usr/include instead of /usr/include/ffmpeg?
No, they're usually in /usr/include/ffmpeg.
> If
> not, I think we should change it and the configure check so they work
> properly, i.e. no special value is required to be given for
> --with-ffmpeg-includes if they've been installed in the standard location.
No, you have to specify the directory if the headers are put in their
own subdirectory.
To be precise, you *must* have a -I switch so that the "internal"
#include directives work. It's established policy to give the user
complete control over which -I or -L switches are used; configure
never adds directories of its own accord.
[We used to try to autodetect directories. It often broke stuff due to
pulling in directories containing incompatible headers (e.g.
incompatibilities between vendor-supplied packages and GNU packages on
commercial Unices), and there was no way to get around it.]
The same reasoning applies to MySQL, PostgreSQL etc. Whether to use
"#include <directory/file.h>" or to use "#include <file.h>" along with
-I/path/to/directory is a property of how the headers are meant to be
used, not where they happen to be installed.
E.g. OpenGL headers are supposed to be included as <GL/gl.h>, X11
headers as <X11/Xlib.h>, Athena headers as <X11/Xaw/Text.h>, etc;
anything else (i.e. moving the prefix to the end of a -I switch) is
incorrect.
Any -I switches are determined according to the installation path
*after* you have determined the correct #include directive.
If a package is designed so that headers are included without any
prefix directory, yet installs them into a package-specific
subdirectory, the intention is that the headers will not be found
without a specific -I switch.
BTW:
	$ pkg-config --cflags libavcodec
Ditto for libavformat and libavutil.
> Also, visualization/nviz/src/Makefile includes references to
> FFMPEGINCPATH, FFMPEGLIBPATH and FFMPEGLIB but as far as I can see none of
> the C files in that directory use any FFmpeg functions - can it be
> removed? (I'm going to test it and see if anything goes wrong...)
In this case, I think that it can be removed, as none of the OGSF
headers appear to include the FFMPEG headers.
