[GRASS-dev] adding lib_arraystats
Moritz Lennert mlennert at club.worldonline.be
Thu Feb 14 05:54:54 EST 2008
On 13/02/08 22:01, Glynn Clements wrote:
> Paul Kelly wrote:
>>> I'm happy that I've been able to launch a discussion about linking R into
>>> GRASS, but could someone tell me if I can check the code into svn ?
>> I can't presume to say anything other than if you feel happy the quality
>> and functionality is up to inclusion in GRASS, go ahead - but if you'd
>> like a couple of comments on it here goes:
>> the typedef STATS looks a little weird to me, (a) because STATS on its own
>> is a very generic sounding name and (b) because in general typedefs are
>> used very little in GRASS (for one thing they confuse me...) I'd suggest
>> something along the lines of "struct GASTATS", avoiding the typedef.
> Agreed. GRASS normally uses structure tags rather than typedefs.
>> EXIT_SUCCESS used as a function exit status looks a bit strange to me too-
>> IIUC this is defined in stdlib.h and intended for programs to return a
>> status code to the enviroment when they exit, not really for internal use
>> by functions.
Thanks to both of you for all your remarks, I'll try to rewrite the code
accordingly.
Concerning EXIT_SUCCESS, I based this on the SUBMITTING file which says:
8.  Exit status is defined as EXIT_SUCCESS or EXIT_FAILURE, e.g.
       if (G_parser (argc, argv))
           exit (EXIT_FAILURE);
       exit (EXIT_SUCCESS);
I guess this should read "Module exit status..." (i.e. not function exit
status) ?
Moritz
