[GRASS-dev] modules have problems with @mapset
Hamish hamish_b at yahoo.com
Thu Feb 14 16:47:39 EST 2008
> Hamish wrote:
> > It is trying to append _{$TMP} after map at mapset instead of just
> > 'map'.
> > Try this:
> >   http://trac.osgeo.org/grass/changeset/30118
> > (really please try that, I haven't tested it)
> > +++ /grass/trunk/scripts/v.db.addtable/v.db.addtable (revision
> 30118)
> > @@ -88,18 +88,20 @@
> >     g.message -e  "Vector map '$GIS_OPT_MAP' not found in current
> > mapset"
> >     exit 1
> > +else
> > +   MAP_NAME=`echo "$GIS_OPT_MAP" | cut -f1 -d'@'`
> >  fi
Glynn:
> Completely bogus. Reverted.
> This just papers over the symptoms without fixing anything.
> If the name includes a mapset which isn't the current one, that's an
> error. You don't just discard the mapset.
note that was placed after a test to see if the map existed in the
current mapset. I now am reminded of the case where the user wants to
use somemap at othermapset when there is already a map of the same name in
the current.
Hopefully what is there now works to everyone's statisfaction.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
