[GRASS-dev] [GRASS GIS] #52: NVIZ fails to display all points in a point vector map
GRASS GIS trac at osgeo.org
Sat Feb 16 13:09:32 EST 2008
 Reporter:  tvrusso                |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                 |      Status:  new
 Priority:  major                  |   Milestone:  6.4.0
Component:  default                |     Version:  unspecified
 Keywords:  NVIZ, display, points  |
 I observed some strange behavior in NVIZ while trying to work through
 examples in the 3rd edition of "Open Source GIS:  A GRASS GIS Approach" by
 Markus Neteler and Helena Mitasova.
 To reproduce:
   - download the nc_spm_06 GRASS location from http://www.grassbook.org/
 under the Data Sets link for 3rd edition
   - Start GRASS with that location and run the command given in Chapter
 3.1, First Steps, on page 33:
     g.region rast=elevation
     nviz elev=elevation vect=streams,roadsmajor, point=overpasses
 When I run the last command, only a single overpass point is displayed.
 See first attached screenshot, where a single red sphere is visible.
 However, if I change the region slightly, say by expanding it five meters
 in all directions:
   g.region -p
   g.region n=228505 s=214995 e=645005 w=629995
 I then see all the points as they should have been, as displayed in second
 screenshot, where multiple points are visible.
 This is with GRASS SVN checked out this morning (and was present in SVN
 for at least the last week, probably longer but this is the first time I
 checked).
Ticket URL: <http://trac.osgeo.org/grass/ticket/52>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
