[GRASS-dev] MASK_OVERRIDE
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Feb 20 04:13:15 EST 2008
On Wed, 20 Feb 2008, Ivan Shmakov wrote:
>>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
> > For this feature to be of real use, you need to allow MASK_OVERRIDE
> > to be used to disable reading a mask altogether. E.g. if
> > MASK_OVERRIDE is defined but empty, no mask should be used rather
> > than falling back to MASK. This would allow the GUI to operate
> > without a mask even when MASK has been created via the command line.
> 	The code doesn't ever fall back to `MASK' if `MASK_OVERRIDE' is
> 	defined.  If `MASK_OVERRIDE' doesn't point to a valid raster
> 	(e. g., if it's an empty string), the mask is ignored.
> 	However, I doubt if it's a reasonable behaviour.  It seems to be
> 	usual in the Unix world to ignore the environment variable's
> 	value if it's an empty string.  Using a non-existing raster
> 	(say, `.') is probably a better idea.
On Windows, an environment variable is unset by setting it to an empty
string. There seems to be no difference between the two. So I don't think
we could rely on the behaviour caused by MASK_OVERRIDE being an empty
string. OTOH setting it to some garbage value seems a little unelegant,
but as long as it's not a valid raster name there should be no problem I
suppose.
Paul
