[GRASS-dev] RE: [GRASS-user] r.describe "Range" output report type -superseded?
Patton, Eric epatton at nrcan.gc.ca
Wed Feb 20 19:24:59 EST 2008
>excuse me if I a miss something but I get (GRASS6.2.2 & 6.3)
> r.describe SRTM3
>READING [SRTM3 in nik] ... 100%
>* -15 -13 -12 -10 thru 2285 2287-2314 2316-2318 2320-2325 2327-2330 2334
>2342
>2344 2347 2349 2350 2357 2358 2361 2365 2375
>and
>r.describe -r SRTM3
>-15 thru -1
>0
>1 thru 2375
You're right, the range is output is only printed with the -r flag. I think I was trying to
reproduce the same behavior without using the flag, and was getting confused in the process.
I'll update the docs accordingly. Thanks,
~ Eric.
