[GRASS-dev] MASK_OVERRIDE
Ivan Shmakov ivan at theory.asu.ru
Wed Feb 20 22:07:39 EST 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
 >> Since the code of both the functions I've modified looks painfully
 >> similar, may I ask for a function to return the (qualified?) name of
 >> the (existing?) mask?  Which file should I put it in?
 >> (There're some modules which could use this function as well.)
 > I would say find_file.c for a generic version, with type-specific
 > versions in find_cell.c and find_vect.c.
	?  Are there a ``generic'' mask facility?
 > The functions in nme_in_mps.c are related, but they only do string
 > operations, not I/O.
