[GRASS-dev] g.mremove bug?
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Thu Feb 21 08:27:41 EST 2008
On Donnerstag, 21. Februar 2008 13:03:11 Moritz Lennert wrote:
> On 21/02/08 12:05, Martin Wegmann wrote:
> > Hello,
> > to validate a modelling module I generated output raster (ca. 10000 - but
> > I did not want to look at each of them ,-) )
> > but when I try to remove them using g.mremove I get:
> > g.mremove rast=out_ST* -f
> > Collecting map names for current mapset <nlm>...
> > Forcing ...
> > /usr/local/grass-6.3.svn/scripts/g.mremove: line
> > 218: /usr/local/grass-6.3.svn/bin/g.remove: Lists of arguments is too
> > long /usr/local/grass-6.3.svn/scripts/g.mremove: line
> > 218: /usr/local/grass-6.3.svn/bin/g.remove: success
> The shell has a maximum line length (and maximum argument number ?)
> which you probably exceed with this list.
> You'd probably be better off doing something like this:
> for map in `g.mlist rast pattern="out_ST*"`
>    do
>      g.remove $map
>    done
thanks, that solved the problem - perhaps we can add it to the g.remove man
page as an example and add a hint in g.mremove.
But removing more than 1000 raster is probably not a very common task.
Martin
University of Wuerzburg
Institute of Geography
Department of Remote Sensing
Am Hubland
97074 Wuerzburg, Germany
German Aerospace Center (DLR)
German Remote Sensing Data Center (DFD)
Environment and Security (US)
Phone:  +49-(0)931-888-4797
Fax:    +49-(0)931-888-4961
Email:  martin.wegmann at uni-wuerzburg.de
