[GRASS-dev] Google Summer of Code 2008
WolfgangZ wollez at gmx.net
Thu Feb 21 16:27:03 EST 2008
Michael Barton schrieb:
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> On Feb 21, 2008, at 10:00 AM, grass-dev-request at lists.osgeo.org wrote:
>> Date: Thu, 21 Feb 2008 09:48:16 -0500
>> From: Helena Mitasova <hmitaso at unity.ncsu.edu>
>> Subject: Re: [GRASS-dev] Google Summer of Code 2008
>> To: GRASS developers list <grass-dev at lists.osgeo.org>
>> Cc: Wolf Bergenheim <wolf+grass at bergenheim.net>
>> Message-ID: <4788DE50-9AB8-418C-856C-462BED4F25FC at unity.ncsu.edu>
>> Content-Type: text/plain; charset=US-ASCII; delsp=yes; format=flowed
>> On Feb 20, 2008, at 2:43 PM, Moritz Lennert wrote:
>>> Some other ideas:
>>>> From the GRASS 7.x ideas collection:
>>> - implement file based spatial index (see "Keep topology and
>>> spatial index
>>> in file instead of in memory" in Radim's Vector ToDo
>>> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/doc/vector/TODO?
>>> rev=HEAD&content-type=text/vnd.viewcvs-markup)
>> I wanted to suggest this one too (this should also remove the need
>> for constant rebuilding of spatial index whenever you want to query
>> vector data)
>> - we should try to find a way how to make this task sound exciting so
>> that there
>> is an interest to do it - or maybe make it part of some of the vector
>> processing topics
>> suggested by Wolf.
>> Another topic that I was thinking about was getting a start for the
>> next generation
>> visualization tool for GRASS - just a simple demo that can be done
>> in 3 months to display surface(s) in 2D and smoothly transfer the
>> view into 3D.
>> Do we have a potential mentor? (I can be the second mentor, but we would
>> need somebody to mentor the programming part).
>> Helena
> I was going to suggest extending v.what to take xy coordinates (single
> xy or line of xy's with a buffer distance to find stuff within that
> buffer distance of the coordinates; set of at least 3 xy's to ID a
> polygon and find the stuff within it).
> However, I want to also strongly second Helena's idea. The new wxPython
> GUI is essentially finished. Now it needs testing, bug fixing,
> optimizing, etc.
> The one piece of the GUI that is not done is a 2.5+D visualizer along
> the lines of NVIZ. As you know, NVIZ is built with a mix of TclTk, a Tk
> OpenGL widget, and C. What we need is something that will run in
> wxPython instead of TclTk. There are various ways to do this, I'm sure
> with pros and cons. My personal preference for interface is that this
> new tool would visually appear in the following way:
> -Start the wxpnviz module and you get a new toolbox window to control
> the N-dimensional view.
> -The module will grab any active maps in your layer tree (i.e., the ones
> you are displaying in 2D in the map display) and render them in 3D --
> sort of like the current NVIZ button tries to do in TclTk now.
> -The 2.5 or 3D image (i.e., include volumes) appears in the same window
> as the 2D map did, replacing the previous view of the 2D map with a
> 2.5/3D rendered image that is controlled by the toolbox. That is, the
> OpenGL canvas could replace the wx.PseudoDC canvas that used for 2D
> display, for example. You would not have a special N-dimensional display
> window that you need to manage separately from other display windows
> (i.e., don't do it like NVIZ does now).
> - All map management would continue to be done through the current layer
> manager, rather than a separate interface (i.e., not the way that NVIZ
> works now).
> - The rendering module would also display overlays like grids,
> barscales, and the like in the same way that the 2D manager does.
> The ideas is that for the user, you don't need to learn a new interface
> for basic map display management to get a N-dimensional visualization.
> The only new interface to learn would be those tools specifically
> related to the N-dimensional visualization (e.g., rotation,
> z-exaggeration, lighting, isosurface selection, etc).
> The other thing that would be nice for many people would be to have a
> command version of the visualizer that could accept a set of arguments
> (or maybe a configuration file) that controlled the display and rendered
> to a PNG instead of the wxPython display window
> Michael
why not to use the python bindings of VTK (http://www.vtk.org) to do 3D
rendering? It seems to me that VTK is a bit easier to handle than OpenGL
directly, but my programming skills are not the best.
WolfgangZ
