[GRASS-dev] [GRASS GIS] #66: v.out.svg: Standardise the `type' option interpretation
GRASS GIS trac at osgeo.org
Fri Feb 22 04:16:54 EST 2008
 Reporter:  1gray        |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  minor        |   Milestone:  7.0.0
Component:  default      |     Version:  unspecified
 Keywords:               |
 Currently {{{v.out.svg}}} interprets its {{{type}}} option in a
 non-standard way, namely:
  * it's not allowed to specify multiple types per {{{v.out.svg}}}
 invocation;
  * the name for the area feature type is {{{poly}}}, while it should be
 {{{area}}}.
  * there's no way to choose only points or centroids for output, only
 both; similarly for lines and boundaries.
 Hence, I suggest the following patch.
 Since the patch breaks the compatibility with the former versions of the
 module, I believe it should only be considered for GRASS 7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/66>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
