[GRASS-dev] adding lib_arraystats
Ivan Shmakov ivan at theory.asu.ru
Fri Feb 22 05:04:56 EST 2008
>>>>> Moritz Lennert <mlennert at club.worldonline.be> writes:
 > Hello, I've finally gotten around to continue working on the
 > d.thematic.* modules, and more specifically on the classification
 > code. As mentioned earlier, I think it makes sense to make the
 > latter into a library, so I decided to create lib_arraystats which
 > contains functions for collecting basic statistics and for finding
 > class breaks in arrays of doubles. In the future this could be
 > filled with more statistical functions on such arrays.
	So, what's the current state of the library?  In particular, did
	you follow the Glynn's suggestions?
	BTW, could you please take a look at raster/r.univar2/stats.c
	and .../r.univar_main.c?  Is there any chance for
	`lib_arraystats' to be used to simplify `r.univar2' as well?
