[GRASS-dev] g.mremove bug?
Fri Feb 22 22:04:31 EST 2008
Ivan Shmakov wrote:
>  > The more fundamental problem with using xargs is that the GRASS
>  > parser requires multiple "answers" for any given option to be
>  > separated by commas, not spaces.
> 	Does it?  IIUC, the following commands are completely equivalent
> 	as long as the GRASS parser is concerned:
> $ g.remove rast=foo,bar
> $ g.remove rast=foo rast=bar
Right; I was thinking specifically about the former case. It's so long
since I've seen the latter form used that I had forgotten about it.
The former case may be slightly more efficient (you'll get more maps
into a maxium-length command line), but it's probably not worth the
additional effort.
>  > That effectively requires g.mremove to collate names itself.
>  > Invoking g.remove once per map is simpler, but it's also inefficient.
> 	Huh?  Even simpler than the following?
Yes.
Generating shell commands using sed then executing them is anything
but simple; particularly when the sed command is itself generated
using shell features (variable substitution).
"while read map ; do g.remove ... ; done" may be more verbose, but
it's much easier to understand.
