[GRASS-dev] Re: [GRASS GIS] #58: v.digit fails to build on Gentoo
GRASS GIS trac at osgeo.org
Sun Feb 24 11:34:50 EST 2008
  Reporter:  marisn    |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  critical  |   Milestone:  6.3.0
 Component:  default   |     Version:  6.3.0 RCs
Resolution:            |    Keywords:  wxGUI, v.digit
Comment (by kyngchaos):
 Same problem here on OSX.  At least on OSX I can directly link in the
 _gdi_.so binary with a full path.  Or you can create the symlink in some
 place you have permissions to write.  BUT, this is still not a good option
 - directly linking binaries to an internal wxpython library just doesn't
 sound right.  Aren't Python binary extensions something that are normally
 loaded by python extension code?
Ticket URL: <http://trac.osgeo.org/grass/ticket/58#comment:3>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
