[GRASS-dev] r.univar: allow multiple rasters to be processed
Ivan Shmakov ivan at theory.asu.ru
Sun Feb 24 13:54:03 EST 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
 > I tried running r.univar on the same map for comparison, but it
 > crashed while trying to compute the percentile (the other statistics
 > were computed okay).
	Is it due to the memory allocation issues, or?
	Anyway, I guess I may commit my patch?  I believe that the other
	issues you've mentioned should be resolved by separate
	changesets.  (And I joyfully commit the ``double'' cast patch
	personally.)
