[GRASS-dev] Google Summer of Code 2008
Soeren Gebbert soerengebbert at googlemail.com
Mon Feb 25 11:03:48 EST 2008
VTK supports 3d render windows as well as 2d render windows and 2d
actors/mappers to visualize
image data. So you are able to use several 2d actors to create layer based
visualizations.
http://www.vtk.org/doc/nightly/html/classvtkActor2D.html
If we are able to bring raster, volume and vector into VTK, we will be able
to use the hundreds of
VTK classes (image, volume and vector) to process grass data.
http://www.vtk.org/doc/nightly/html/classes.html
Which IMHO will bring us enormous benefit in form of parallel image
processing and
complex image-vector, vector-vector and vector-volume algorithms.
Just my 2c
Soeren
2008/2/25, benjamin.ducke at ufg.uni-kiel.de <benjamin.ducke at ufg.uni-kiel.de>:
> > why not to use the python bindings of VTK (http://www.vtk.org) to do 3D
> > rendering? It seems to me that VTK is a bit easier to handle than OpenGL
> > directly, but my programming skills are not the best.
> > WolfgangZ
> Apart from the problem with limited coordinate ranges brought about by
> OpenGL, VTK uses a visualization pipeline rather than layers. There is
> nothing wrong with this per se, but GIS users are accustomed to layers
> that cover each other in a pre-defined order, even if there is no
> difference in the Z coordinates. VTK projects all objects into the same
> 3D space, potentially giving unexpected results, e.g. when overlaying
> vector outlines on a raster surface without raising the former a little
> bit towards the zenith.
> Might be worth thinking about this. I don't know how easy or complicated
> it would be to emulate a layer-based drawing on a VTK rendering
> pipeline.
> Benjamin
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080225/76ad1d06/attachment.html
