[GRASS-dev] PostgreSQL supports needed by GRASS
Mon Feb 25 11:56:39 EST 2008
marco.pasetti at alice.it wrote:
> building PostgreSQL for windows using MinGW, I'm querying as follows:
> enabling PostgreSQL support in GRASS, what PGSQL enabled features does
> GRASS require (or, better, you suggest to enable)?
> - python? (supposed to be python enabled in GRASS)
> - openssl?
> - libxml?
> - thread-safety?
AFAIK, GRASS doesn't use any of those features directly. There may be
reasons to enable some of them, but those reasons aren't directly
related to GRASS.
BTW, is there a particular reason to compile from source? Precompiled
PostgreSQL binary packages are available for Windows.
