[GRASS-dev] way to create PROJ_INFO and PROJ_UNITS
andrea antonello andrea.antonello at gmail.com
Mon Feb 25 12:02:01 EST 2008
Thanks,
I didn't notice the "modifies current location unless 'location'
option specified".
I would like to try once more to start a discussion about
standardization (or call it whatever you want) of the projection
information.
All projects that are not using proj have problems to guess and
reconstruct the projection of a GRASS workspace.
Would it be possible to create also a PROJ_INFO.WKT well known text
version of the file whenever a location is created? This would greatly
enhance interoperability between projects, which imho, is necessary.
Comments welcome,
Andrea
>  > Hi, assume I create a location from outside GRASS and need to create
>  > the PROJ_INFO and PROJ_UNITS files, since without proj there is no way
>  > to do that.
>  > Is there a way to create those file through g.proj from null, best if
>  > supplying the epsg code?
>         g.proj -c epsg=...
>  Glynn Clements <glynn at gclements.plus.com>
