[GRASS-dev] Manpage HTML markup consistency
Tue Feb 26 01:27:42 EST 2008
Dylan Beaudette wrote:
> I wonder if now would be a good time to investgate the use of CSS in the man
> pages. If we define a couple types of "container" objects (<div>, <span>,
> etc) we can use a single style file to later manipulate the look and feel of
> the manual pages.
If you're going to overhaul the documentation, I suggest going all the
way and using something which is intended to be used as a source for
multiple formats (at least HTML and nroff, with one or more of TeX,
PDF and PostScript as options), e.g. DocBook.
