[GRASS-dev] way to create PROJ_INFO and PROJ_UNITS
Hamish hamish_b at yahoo.com
Tue Feb 26 01:38:18 EST 2008
andrea antonello wrote:
> All projects that are not using proj have problems to guess and
> reconstruct the projection of a GRASS workspace.
> Would it be possible to create also a PROJ_INFO.WKT well known text
> version of the file whenever a location is created? This would
> greatly enhance interoperability between projects, which imho,
> is necessary.
You can get this info at any time from g.proj:
Flags:
  -p   Print projection information (in conventional GRASS format)
  -d   Verify datum information and print transformation parameters
  -j   Print projection information in PROJ.4 format
  -w   Print projection information in WKT format
  -e   Use ESRI-style format (applies to WKT output only)
  -f   Print 'flat' output with no linebreaks (applies to WKT and
PROJ.4 output)
Hamish
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
