[GRASS-dev] Fwd: problem regarding the display of map
Arun verma kumar.arun417 at gmail.com
Tue Feb 26 06:29:09 EST 2008
---------- Forwarded message ----------
Date: Feb 25, 2008 5:34 PM
Subject: problem regarding the display of map
To: grass-user at lists.osgeo.org, grass-dev at lists.osgeo.org
hi,
i convert the raster map to vector map and the name of new vect map is
map_tf_v
but when i use the display command i am getting following error
g.region vect=map_tf_v
ERROR: Cannot open old vector map_tf_v at PERMANENT on level 2
 d.vect map=tgr_shp
The bounding box of the map is outside the current region, nothing drawn.
how can i display the map...???
thanks & regards
Arun K Verma
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080226/52742bc6/attachment.html
