[GRASS-dev] Re: [GRASS GIS] #68: grass libraries sonames
GRASS GIS trac at osgeo.org
Tue Feb 26 10:41:11 EST 2008
  Reporter:  wrobell  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.3.0
 Component:  default  |     Version:  6.3.0 RCs
Resolution:           |    Keywords:
Comment (by glynn):
 Replying to [ticket:68 wrobell]:
 > grass build system does not set sonames of libraries. it causes problems
 > while packaging grass using i.e. rpm which uses sonames for
 dependencies.
 > link to the patch
 > http://cvs.pld-linux.org/cgi-bin/cvsweb.cgi/SOURCES/grass-soname.patch
 GRASS is supposed to compile on platforms other than Linux, so hard-coding
 platform-specific linker switches is bogus.
 The correct way to fix this is to modify the "Linux" portion of the
 SC_CONFIG_CFLAGS macro in aclocal.m4.
Ticket URL: <http://trac.osgeo.org/grass/ticket/68#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
