[GRASS-dev] [GRASS GIS] #70: i.target from GUI: strip @mapset part
GRASS GIS trac at osgeo.org
Tue Feb 26 21:08:14 EST 2008
 Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  minor    |   Milestone:  6.4.0
Component:  default  |     Version:  svn-trunk
 Keywords:           |
 if you call i.target from a GUI and select a group it appends @mapset. If
 you run it like that it takes the full name literally and instead of
 updating the group's target it creates a new group of name "group at mapset".
 Either i.target or I_put_target() should check that if the @mapset part is
 given it refers to the current mapset, then strip off the @mapset part.
 Otherwise you end up with
 GRASS> g.list group
 group
 group at mapset
 group at mapset@mapset
 etc.
 I changed the group option gisprompt from old,group,group to any,gr,gr.
 This makes the GUI group picker button go away, but perhaps the GUI picker
 button should be coded to remain in that case?
 Or to solve this should we try changing the gisprompt to mapset,gr,gr so
 it calls G_ask_in_mapset()?
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/70>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
