[GRASS-dev] Re: [GRASS GIS] #70: i.target from GUI: strip @mapset part07
Michael Barton michael.barton at asu.edu
Wed Feb 27 10:01:57 EST 2008
On Feb 27, 2008, at 1:47 AM, grass-dev-request at lists.osgeo.org wrote:
> Date: Wed, 27 Feb 2008 02:08:14 -0000
> From: "GRASS GIS" <trac at osgeo.org>
> Subject: [GRASS-dev] [GRASS GIS] #70: i.target from GUI: strip @mapset
> 	part
> To: undisclosed-recipients:;
> Message-ID: <040.2d24057011b5108d92306c223fc7f99a at osgeo.org>
> Content-Type: text/plain; charset="utf-8"
>  Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
>      Type:  defect   |      Status:  new
>  Priority:  minor    |   Milestone:  6.4.0
> Component:  default  |     Version:  svn-trunk
>  Keywords:           |
>  Hi,
>  if you call i.target from a GUI and select a group it appends
> @mapset. If
>  you run it like that it takes the full name literally and instead of
>  updating the group's target it creates a new group of name
> "group at mapset".
>  Either i.target or I_put_target() should check that if the @mapset
> part is
>  given it refers to the current mapset, then strip off the @mapset
> part.
>  Otherwise you end up with
>  GRASS> g.list group
>  group
>  group at mapset
>  group at mapset@mapset
>  etc.
>  I changed the group option gisprompt from old,group,group to
> any,gr,gr.
>  This makes the GUI group picker button go away, but perhaps the
> GUI picker
>  button should be coded to remain in that case?
>  Or to solve this should we try changing the gisprompt to
> mapset,gr,gr so
>  it calls G_ask_in_mapset()?
The GUI uses the global $GISBASE/etc/element.list to ID parsable
element types. "gr" is not in the list (unless you've added it since
last night). So it isn't parsed by the GUI. To solve this at the GUI
level, we would need to changed the command parsers (in TclTk and
wxPython) to either 1) read all "group" elements without "@mapset" or
2) create a new element that represents a "group" without
"@mapset" (e.g. "gr") and specify how and where it should be parsed.
 From the thread about this that I started a couple weeks ago, there
seem to be some difference of opinion on how to fix the issues about
reading "@mapset". This can be dealt with in the GUI for the specific
cases where it's a problem. However, Glynn's point (I hope I'm
summarizing this correctly) is that this is a problem at the module
level and should be solved there instead of stripping out the
"@mapset" at the GUI level. I think we need to get this settled so we
can decide where to start fixing things.
Michael
