[GRASS-dev] Re: 'g.gui wxpython' won't work in wingrass as wxgui is a shell script
Thu Feb 28 17:08:43 EST 2008
Ivan Shmakov wrote:
> 	Apparently, the only problem preventing the use of Gnulib in
> 	GRASS is that it may require a newer Autoconf.
A C file won't care about which autoconf version (if any) was used, so
long as the right macros are defined.
