R: R: [GRASS-dev] winGRASS 6.3.0RC5 errors
Marco Pasetti marco.pasetti at alice.it
Thu Feb 28 19:03:23 EST 2008
>can you try to use grass_trunk for testing on Windows?
Sure. But, sorry, not immediately; I'm trying to build a "full working"
version of GRASS + QGIS and, at the same time, write the relative building
guide. Now I need my PC to build QGIS and prepare a selfcontained installer
of GRASS and QGIS (separately); then I'll work on trunk... Working with a 3
years old PC, using MinGW over Windows, makes buildings very, very slow
(GRASS takes about 2,5 hours to compile!!... And meanwhile the PC is quite
unusable)
What do you think about my guide?
Goodnight,
Marco
-----Messaggio originale-----
Da: Martin Landa [mailto:landa.martin at gmail.com]
Inviato: venerdì 29 febbraio 2008 0.15
A: Glynn Clements
Cc: Marco Pasetti; grass-dev at lists.osgeo.org
Oggetto: Re: R: [GRASS-dev] winGRASS 6.3.0RC5 errors
2008/2/28, Glynn Clements <glynn at gclements.plus.com>:
>  Marco Pasetti wrote:
>  >   File "C:/MSYS/local/grass-6.3.0RC5/etc/wxpython/gis_set.py", line
356, in
>  > _read_grassrc
>  >     key, val = line.split(":")
>  > ValueError: too many values to unpack
Glynn:
> This should be changed to:
>         key, val = line.split(":", 1)
>  The code only expects to find a single colon in each line, separating
> the key and the value. But the value itself may contain a colon; in
> particular, GISDBASE on Windows will contain a colon after the drive
> letter.
fixed in trunk
http://trac.osgeo.org/grass/changeset/30396
will be backported to releasebranch_6_3 before releasing 6.3.0. Marco, can
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
