[GRASS-dev] r.terraflow Windows patch
Moritz Lennert mlennert at club.worldonline.be
Fri Feb 29 11:42:41 EST 2008
On Sun, February 24, 2008 18:06, Glynn Clements wrote:
> Moritz Lennert wrote:
>> > Can someone test the attached patch on Windows (MSys)?
>> I now get:
>> main.cc: In function `void record_args(int, char**)':
>> main.cc:327: error: `ctime_r' undeclared (first use this function)
> The attached patch should fix that issue.
> If there are any remaining errors, please use "make -k", so that you
> get all of them.
Log attached.
Moritz
Type: application/gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080229/9ee32acf/r.terraflow.make.log.bin
