[GRASS-dev] [GRASS-trac] #13: GRASS OGR Module failing
GRASS-trac trac at osgeo.org
Sat Jan 5 23:40:54 EST 2008
 Reporter:  jrobins     |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  default     |     Version:  unspecified
 Keywords:  OGR,Cygwin  |
 The GDAL/OGR module fails when I try to export ESRI shapefiles from GRASS
 vectors.
 Cygwin/X Output on startup:
 Welcome to the XWin X Server
 Vendor: The Cygwin/X Project
 Release: 6.8.99.901-4
 Contact: cygwin-xfree at cygwin.com
 XWin was started with the following command line:
 X :0 -multiwindow -clipboard
 _XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
 winValidateArgs - g_iNumScreens: 1 iMaxConsecutiveScreen: 1
 (II) XF86Config is not supported
 (II) See http://x.cygwin.com/docs/faq/cygwin-x-faq.html for more
 information
 winDetectSupportedEngines - Windows NT/2000/XP
 winDetectSupportedEngines - DirectDraw installed
 winDetectSupportedEngines - DirectDraw4 installed
 winDetectSupportedEngines - Returning, supported engines 00000007
 winSetEngine - Multi Window or Rootless => ShadowGDI
 winAdjustVideoModeShadowGDI - Using Windows display depth of 32 bits per
 pixel
 winAllocateFBShadowGDI - Creating DIB with width: 1280 height: 800 depth:
 32
 winFinishScreenInitFB - Masks: 00ff0000 0000ff00 000000ff
 winInitVisualsShadowGDI - Masks 00ff0000 0000ff00 000000ff BPRGB 8 d 24
 bpp 32
 null screen fn ReparentWindow
 null screen fn RestackWindow
 InitQueue - Calling pthread_mutex_init
 InitQueue - pthread_mutex_init returned
 InitQueue - Calling pthread_cond_init
 InitQueue - pthread_cond_init returned
 winInitMultiWindowWM - Hello
 winInitMultiWindowWM - Calling pthread_mutex_lock ()
 winMultiWindowXMsgProc - Hello
 winMultiWindowXMsgProc - Calling pthread_mutex_lock ()
 MIT-SHM extension disabled due to lack of kernel support
 XFree86-Bigfont extension local-client optimization disabled due to lack
 of shar
 ed memory support in the kernel
 (--) Setting autorepeat to delay=500, rate=31
 (--) winConfigKeyboard - Layout: "00000409" (00000409)
 (--) Using preset keyboard for "English (USA)" (409), type "4"
 Rules = "xorg" Model = "pc105" Layout = "us" Variant = "(null)" Options =
 "(null
 (--) 5 mouse buttons found
 Could not init font path element /usr/X11R6/lib/X11/fonts/CID/, removing
 from li
 st!
 Could not init font path element /usr/X11R6/lib/X11/fonts/100dpi/,
 removing from
  list!
 winPointerWarpCursor - Discarding first warp: 640 400
 winInitMultiWindowWM - pthread_mutex_lock () returned.
 winProcEstablishConnection - Hello
 winMultiWindowXMsgProc - pthread_mutex_lock () returned.
 winInitMultiWindowWM - pthread_mutex_unlock () returned.
 winMultiWindowXMsgProc - pthread_mutex_unlock () returned.
 winInitMultiWindowWM - DISPLAY=127.0.0.1:0.0
 winMultiWindowXMsgProc - DISPLAY=127.0.0.1:0.0
 cat: /home/John/.Xauthority: No such file or directory
 winInitClipboard ()
 winProcEstablishConnection - winInitClipboard returned.
 winClipboardProc - Hello
 DetectUnicodeSupport - Windows NT/2000/XP
 winClipboardProc - DISPLAY=127.0.0.1:0.0
 winMultiWindowXMsgProc - XOpenDisplay () returned and successfully opened
 the di
 splay.
 winInitMultiWindowWM - XOpenDisplay () returned and successfully opened
 the disp
 lay.
 winClipboardProc - XOpenDisplay () returned and successfully opened the
 display.
 winProcSetSelectionOwner - Clipboard not yet started, aborting.
 --Execute 'grass62' at xWin prompt--
 Cygwin/X output in Cygwin shell:
 winMultiWindowXMsgProcErrorHandler - ERROR: BadWindow (invalid Window
 parameter)
 parameter)
 --select spearfish60 location; PERMANENT mapset--
 Grass output in xWin shell:
 Cleaning up temporary files.....
 Starting GRASS ...
 /usr/local/grass-6.2.3/etc/Init.sh: line 635: tput: command not found
 Welcome to GRASS 6.2.3 (2007)
 GRASS homepage:                          http://grass.itc.it/
 This version running thru:               GNU Bash (Cygwin)
 (/usr/bin/bash.exe)
 Help is available with the command:      g.manual -i
 See the licence terms with:              g.version -c
 If required, restart the graphical user interface with: gis.m &
 When ready to quit enter:                exit
 GRASS 6.2.3 (spearfish60):~ >
 --error is generated here--
 GRASS 6.2.3 (spearfish60):~ > v.out.ogr input=roads type=line
 dsn=/shapefiles olayer=Road
 Segmentation fault (core dumped)
 Output in Cygwin shell:
      24 [main] v.out.ogr 2480 _cygtls::handle_exceptions: Error while
 dumping st
 ate (probably corrupted stack)
 --data dumped to v.out.ogr.stackdump in my home directory
 (c:\cygwin\home\John\)--
 Is this an OGR problem, or is this a GRASS issue?  It started happening
 recently, but I can
 now reproduce it reliably.  I am running GRASS 6.2.3 on Windows Vista
 using all the latest updates
 from Cygwin (v. 1.5.25-7), from the Cygwin/X Project (v. 6.8.99.901-4),
 and from GDAL
 (v. 1.3.1-1).
 Thanks,
 John R.
Ticket URL: <http://trac.osgeo.org/grass/ticket/13>
GRASS-trac <http://grass.osgeo.org>
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies.
