[GRASS-dev] d.legend uses a static buffer for `map='
Martin Landa landa.martin at gmail.com
Mon Jan 7 04:48:18 EST 2008
applied in trunk, thanks. Regards, Martin
http://trac.osgeo.org/grass/changeset/29587
2008/1/7, Ivan Shmakov <ivan at theory.asu.ru>:
>         As of a recent SVN HEAD, `d.legend' uses a static buffer to
>         store the value of the `map' option.  It's therefore impossible
>         to pass raster names more than 63 bytes long to `d.legend'.
>         Since I don't see why a static buffer may be necessary here, I
>         suggest the following (yet untested) patch.
> diff --git a/display/d.legend/main.c b/display/d.legend/main.c
> index d827d04..324012d 100644
> --- a/display/d.legend/main.c
> +++ b/display/d.legend/main.c
> @@ -39,7 +39,7 @@ int main( int argc, char **argv )
>         char *mapset ;
>         char buff[512];
> -       char map_name[64] ;
> +       const char *map_name;
>         char window_name[64] ;
>         int black ;
>         int cats_num ;
> @@ -188,7 +188,7 @@ int main( int argc, char **argv )
>         if (G_parser(argc, argv))
>                 exit(EXIT_FAILURE);
> -       strcpy(map_name, opt1->answer) ;
> +       map_name = opt1->answer;
>          hide_catstr = hidestr->answer;  /* note hide_catstr gets changed and re-read below */
>          hide_catnum = hidenum->answer;
> PS.  I've seen a number of other uses of static buffers scattered across
>         the code, leading to both potential limits and crashes, which
>         I'm on the way to investigate.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
