[GRASS-dev] [grass-doc I][574] v.in.ogr
Patton, Eric epatton at nrcan.gc.ca
Mon Jan 7 14:14:05 EST 2008
>> Initial Comment:
>> In v.in.ogr (in the gui), in the "output name" field [Name for output vector map:], in the descriptive text in the parenthesis it sais:
>> "(output: name, optional)"
>> Should the optional be "required"?
>IIRC it is optional because you might want to just list the available
>layers in the input OGR source (-l flag), in which case you don't need to
>specify an output map.
>Paul
My bad; through a weird coincidence I was already editing the description.html for v.in.ogr
when Nikos's bug report came through the list. I thought he was reporting the man page typo that I was
in the midst of correcting. I haven't changed the output parameter to 'required' either in the C code
or the docs.
~ Eric.
