[GRASS-dev] batch search and replace from command line?
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Wed Jan 9 09:19:16 EST 2008
Works fine again.
Cheers for the quick fixing.
Benjamin
Markus Neteler wrote:
> Sorry, fixed in SVN.
> Markus
> On Jan 9, 2008 2:51 PM, Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de> wrote:
>> With a fresh checkout from SVN (done about 3 hours ago),
>> I now get:
>> Error in startup script: can't create procedure "GmLib::errmsg": unknown
>> namespace
>>     while executing
>> "proc GmLib::errmsg { error args } {
>>     # send error report and optional message (args) to tk_messageBox
>>     set message ""
>>     if { $args !..."
>>     (file "/usr/local/grass-6.3.svn/etc/gm/gm.tcl" line 543)
>> when trying to launch gis.m
>> Best,
>> Benjamin
>>> Done and submitted:
>>>   http://trac.osgeo.org/grass/changeset/29624
>>> I have used attached script.
>>> Cheers
>>> Markus
>>> On Jan 9, 2008 7:02 AM, Michael Barton <michael.barton at asu.edu> wrote:
>>>> I'm betting there is a Unix command to do a batch search and replace of one
>>>> string with another in all text files in a directory.
>>>> But I don't know what it is.
>>>> I'm trying to follow Glynn's advice to create a library of common TclTk
>>>> procedures that can be called without calling another instance of gm.tcl
>>>> (i.e., without launching another GIS Manager window).
>>>> These procedures (e.g., Gm::errmsg) get called a LOT in many modules. I'd
>>>> like a way of replacing every occurance of "Gm::errmsg" with "GmLib::errmsg"
>>>> in all modules in the TclTk GUI directory.
>>>> Can someone tell me if this is possible and, if so, how to do it?
>>>> Thanks
>>>> Michael
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Benjamin Ducke, M.A.
>> Archäoinformatik
>> (Archaeoinformation Science)
>> Institut für Ur- und Frühgeschichte
>> (Inst. of Prehistoric and Historic Archaeology)
>> Christian-Albrechts-Universität zu Kiel
>> Johanna-Mestorf-Straße 2-6
>> D 24098 Kiel
>> Germany
>> Tel.: ++49 (0)431 880-3378 / -3379
>> Fax : ++49 (0)431 880-7300
>> www.uni-kiel.de/ufg
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
