[GRASS-dev] table only creation in v.in.ascii
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Thu Jan 10 10:19:42 EST 2008
OK, this seems to be a useful hint, so here it goes again:
Martin Landa wrote:
> hi,
> it is better to create one diff file instead of bunch of them, e.g.
> svn diff vector/v.in.ascii > v-in-ascii.diff
> sorry for bothering you:-)
> Martin
> 2008/1/10, Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>:
>> Alright, here is the patches vor v.in.ascii.
>> Cheers,
>> Benjamin
>> Benjamin Ducke wrote:
>>> Unfortunately, it returns DB_OK.
>>> There seems to be some caching going on which I don't quite
>>> understand at the moment.
>>> Starting and stopping the db driver in the right sequence seems
>>> to be important.
>>> Anyway, I solved the problem by doing the deletion at an earlier
>>> point in the program.
>>> Everything seems to work OK now. I'll do some tests with more
>>> complex tables, then post a patch.
>>> Benjamin
>>> Moritz Lennert wrote:
>>>> On 10/01/08 13:52, Benjamin Ducke wrote:
>>>>> OK, I have it almost working except for one annoyance:
>>>>> If the table already exists, then --o should allow the user to
>>>>> overwrite it. Thus, I check for that flag and delete the old
>>>>> table, if it exists, using:
>>>>>   db_delete_table ( connection.driverName, connection.databaseName,
>>>>>                     new->answer );
>>>>> But even so, the next call to
>>>>>   db_execute_immediate()
>>>>> complains about the table still being there and creation of the
>>>>> new table fails.
>>>>> I suppose that db_delete_table() does not delete the table immediately?
>>>> db_delete_table() sends a "drop table XYZ" sql query to the database
>>>> backend, so it should delete the table.
>>>> Launching
>>>> echo "drop table ggg" | db.execute
>>>> followed by
>>>> echo "create table ggg (cat int, value double)" | db.execute
>>>> works without a problem.
>>>> What does db_delete_table return ?
>>>> Moritz
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Benjamin Ducke, M.A.
>> Archäoinformatik
>> (Archaeoinformation Science)
>> Institut für Ur- und Frühgeschichte
>> (Inst. of Prehistoric and Historic Archaeology)
>> Christian-Albrechts-Universität zu Kiel
>> Johanna-Mestorf-Straße 2-6
>> D 24098 Kiel
>> Germany
>> Tel.: ++49 (0)431 880-3378 / -3379
>> Fax : ++49 (0)431 880-7300
>> www.uni-kiel.de/ufg
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080110/0a3b7fcb/v.in.ascii-0001.bin
