[GRASS-dev] use of WIND_OVERRIDE in GRASS
Markus Neteler neteler at osgeo.org
Fri Jan 11 09:15:42 EST 2008
Patch applied to SVN-HEAD.
Thanks, Ivan.
Markus
On Jan 7, 2008 10:27 AM, Ivan Shmakov <ivan at theory.asu.ru> wrote:
> >>>>> Glynn Clements <glynn at gclements.plus.com> writes:
>  >> exec `g.region rast="$RAST"`
>  > This is bogus on two counts. First, g.region doesn't output a shell
>  > command, so the use of exec and backticks makes no sense. Second,
>  > shell scripts shouldn't change the current region; they should create
>  > a temporary region with "g.region ... save=..."  and use
>  > WIND_OVERRIDE.
>         Apparently, there're a couple of scripts to be fixed in GRASS
>         itself.  An (untested) patch follows.
> diff --git a/scripts/i.fusion.brovey/i.fusion.brovey b/scripts/i.fusion.brovey/i.fusion.brovey
> index ce0be15..8cde5ea 100755
> --- a/scripts/i.fusion.brovey/i.fusion.brovey
> +++ b/scripts/i.fusion.brovey/i.fusion.brovey
> @@ -118,8 +118,6 @@ export LC_NUMERIC
>  cleanup()
> - #restore settings:
> - g.region region=i.fusion.brovey.$TMP
>   g.remove region=i.fusion.brovey.$TMP > /dev/null
> @@ -137,10 +135,12 @@ if [ $? -ne 0 ] ; then
>   exit 1
>  fi
> -#save current settings:
> +# clone current region
>  g.region save=i.fusion.brovey.$TMP > /dev/null
> +WIND_OVERRIDE=i.fusion.brovey.$TMP
> +export WIND_OVERRIDE
> -g.message message="Temporarily setting raster resolution to PAN resolution: $PANRES"
> +# set the resolution
>  g.region res=$PANRES -ap > /dev/null
>  g.message "Performing Brovey transformation..."
> diff --git a/scripts/i.in.spotvgt/i.in.spotvgt b/scripts/i.in.spotvgt/i.in.spotvgt
> index 826b307..25cbab1 100755
> --- a/scripts/i.in.spotvgt/i.in.spotvgt
> +++ b/scripts/i.in.spotvgt/i.in.spotvgt
> @@ -200,8 +200,10 @@ g.message message="Imported SPOT VEGETATION NDVI map <$NAME>."
>  # Coefficient a = 0.004
>  # Coefficient b = -0.1
> -#save region before zoom to SPOT image
> -g.region save=spot_$PID 2>&1 >/dev/null
> +# switch to a temporary region
> +WIND_OVERRIDE=spot_$PID
> +g.region -d 2>&1 >/dev/null
>  g.region rast=$NAME 2>&1 >/dev/null
>  g.message "Remapping digital numbers to NDVI..."
> @@ -276,8 +278,7 @@ EOF
>    g.message message="Filtered SPOT VEGETATION NDVI map <${NAME}_filt>."
>  fi
> -# restore user settings:
> -g.region region=spot_$PID 2>&1 >/dev/null
> +# remove the temporary region
>  g.remove region=spot_$PID 2>&1 >/dev/null
>  #### clean up the mess
