[GRASS-dev] Help > About System fixed
Fri Jan 11 16:25:32 EST 2008
Michael Barton wrote:
> I don't know why I didn't see this before.
> It turned out to be simple to fix the problem with the Help > About
> System module. Someone had added a line ...
> source $env(GISBASE)/etc/gm/gm.tcl
> This line launched the GIS Manager every time About System was run.
I pointed this out about 50 messages back ;)
The reason that line was added is that tksys.tcl was changed to use
Gm::errmsg, which is (or was) defined in gm.tcl.
